Advocate I
Advocate I
@TCopp is correct, the word is some of the optional equip is impacting the GVWR limitation which seems crazy for what is supposed to be a heavy duty off road capable truck. As far as AM options for those items, I haven't seen much yet but multiple companies have released they are in process with designing equip for the new Bronc. I would not be worried...there will be a plethora of support from the AM vendors similar to Jeep.Am I missing something on the B&P that I can't add Roof Rails on the Bad Lands/Sasq variant? On a related note, anyone recommend alternative config using aftermarket for rails, light bar with one of the Yakama racks?
Yours is a 2dr isnt it? It wont go on a 4dr.I have them on my badlands build, from day one.
Yeah, but the OP didnt specify 4DYours is a 2dr isnt it? It wont go on a 4dr.
No but if you've read other posts regarding the roof racks and rails, you would have been able to figure out that was what the problem was.Yeah, but the OP didnt specify 4D
Ok, so the OP should have read the other posts?No but if you've read other posts regarding the roof racks and rails, you would have been able to figure out that was what the problem was.
0884
First off, you are not the first to discover how the B&P system has some dependencies. Keep in mind, those were placed there for a reason.Am I missing something on the B&P that I can't add Roof Rails on the Bad Lands/Sasq variant? On a related note, anyone recommend alternative config using aftermarket for rails, light bar with one of the Yakama racks?
0215
Yeah, you should be able to buy them from the dealer and install them yourself.I just like the look of them rails. I'll probably never rig anything up there and risk scratching them up. I'm getting a 4-door for cargo space. Pulling a camp trailer.
Advocate I
Thanks for the feedback. I admit I'm not familiar with the details you mention. I'm mostly interested in a flat platform option for elevated photography. But its good to know about the GVWR.First off, you are not the first to discover how the B&P system has some dependencies. Keep in mind, those were placed there for a reason.
Like yourself, I plan to purchase a 2021 Bronco Badlands. The Badlands model is a superbly engineered vehicle. It should successfully allow me to complete many difficult trails. Achieving that goal required an understanding of dynamic and static weight limits as well as gross vehicle weight rating.
As you research aftermarket roof rail alternatives, the following thread might be of interest.
Rhino-Rack Pioneer Platform Backbone Rack | Bronco Nation Forum (thebronconation.com)
Please keep in mind, it is not as simple as finding an aftermarket roof rail that will fit your Bronco. You should gain a working knowledge of GVWR and how a rail system might impact the options you select when ordering your Badlands. Although I hope to purchase a system such as the Backbone Rack identified in the thread above, it requires me to adjust my Badlands options to avoid weight issues based on my intended use during multi-day camping trips.
Remember both the Badlands and the First Edition are the most capable models. As such, they can have the most challenging weight issues based on your intended use.
