37" Tire Testing - More Detail
allan
Supporter III
Feb 26, 2020
256
1,395
2,134
Dearborn, MI, USA
Allan
Dunlap
0020
Here it is!
Ford announced on Friday that they are testing 37-inch tires on the performance derivative of Bronco. Early testing shots obtained exclusively by Bronco Nation show the 4-door 2021 Ford Bronco riding on what appear to be BFGoodrich KO2 All-Terrain tires. Additionally, a wider track and wider fender flares seem to be on this vehicle to keep center of gravity low despite the increased ride height.
In4low
Champion III
Aug 6, 2020
17
27
846
Detroit, MI, USA
Esteban
Jennings
Here it is!
Talk about meats.
JFord
Supporter III
Aug 18, 2020
217
381
2,461
California, USA
Jason
Ford
1184
I feel like the performance bronco will be awesome. I feel like 38” is about as big as you can go without looking like you’re trying to build a monster truck.
What’s the possibility of a two door version of the performance Bronco?
guzie
Supporter I
Jul 25, 2020
126
200
1,192
Grand Rapids mi
Kevin
Guzniczak
0988
I think it will only be the 4dr version. The 4dr is more stable for higher speed off road running with the longer wheelbase on the normal bronco. Adding even larger tires like the 37” setup along with more width makes the instability even worse in a 2dr. You don’t want a condition where your width is close the your length and be close to square dimensionally.
Reactions: Deano Bronc
lowmpg
Supporter I
Aug 3, 2020
121
197
1,192
Stevensville, MD, USA
Ryan
Wagner
0846
If they are throwing 37's on it, it will come on both vehicles.
JFord
Supporter III
Aug 18, 2020
217
381
2,461
California, USA
Jason
Ford
1184
Here it is!
@allan, do you have any insight into HP ratings Ford thinks they will need to turn the larger tires (Powertrain options) as well as a more firm estimate on availability dates? If this Bronco could be available in 2022 and will have a better HP rating, it might be worth the wait. Oh yeah, could there be a two door version in the shadows?
LoneRanger
May 20, 2020
396
594
3,144
Williston, FL, USA
Rob
Incognito
0102
less to do with HP and more to do with gears (axle, or transmission).
L.R.
